1 - 6 of 6 Posts
Not going in gear after thinking it’s the pump . It was the converter. (2700-3000 stall)Got it to pump and now not going into gear at all.. please help
I think I have tried everything I know
True Hotrodder
More information would help here. Is this a recent rebuild? Professional or other? Did the convertor fail or was it not installed correctly? What about fluid levels? And are you speaking of mechanically not going into gear or you are moving the shifter arm through the gear range (drive wheels in the air and chassis supported) and not getting any rotation from the output shaft?
Burnt out transmission tech.
Got it tp pump? Explain that please.
Hates: Liver. Loves: Diesel
Sounds like TC not installed correctly, he ran it, then properly installed the TC and discovered that the pump is destroyed. That's my guess.
True Hotrodder
Might be he busted the gearset, if he hasn't run it too much like that he might be able salvage the pump with a new set of gears.
Running it without the pump functioning will destroy it in a hurry. Like flat towing it without removing the driveshaft.
1 - 6 of 6 Posts
