Status
Not open for further replies.
Hey. I had to order a new forward drum w/ input shaft.
But they sent me one with the later style input shaft that has the teflon seal where it goes in the output shaft.
It will fit now that I pulled the bushing........but the shaft is 1/4" shorter than my old one.......and the spline length on the input side is not as long either.
Will this work or should I get the earlier style drum/input shaft?
Thanks, z
WFO
Thanks, z
If by "later style input shaft" you mean the shaft is for the TH350C w/lock up torque converter (used 1981- up), a non lock up torque converter will not fit the lock up style shaft.
If this is the case, get the older non lock up style input shaft.
No that's not it. Chevy upgraded the input shaft in 77 or so.......when you pull the bushing out of the output shaft, the newer style will fit ........but I worry about it being 1/4 inch shorter.......and the spline length being shorter too.....Sessions talks about the bushing/newer teflon seal....but doesn't elaborate on switching them......
z
I toss out the shaft with the teflon seal....
the nick is nothing to worry about, unless there is a crack. oh wait, that question was on yellow bullet forum
Status
