hey im having problems with my th350 automatic transmission which is not shifting into 2nd gear. i had just recently dropped the pan and reconnected the s-link going to he linkage and forgot to clean the inside of the pan so i think it could be gummed up. ive also had a bad vacuam problem which causes me to be driving double-footed most of the time. i didnt know if this wouldve adversely affected the transmission, let me know if you have any solutions.
Yes, the vacuum modulator is mounted on the transmission and has a rubber line going to it . This is what helps your transmission shift gears. If the modulator or line has a vacuum leak, your transmission won't shift gears. Hope this helps, Bill.
