I believe the TH350 pump is like the TH400, where two of the pump-to-case bolt holes are tapped for the slide hammer. I believe they are the two at 3:00 and 9:00. The Kent Moore tools for this are a pair of small slide hammers so you can pull both sides at once, but I've had no problems pulling the pump on a TH400 by using a single slide hammer and going back and forth between the two holes. I fabricated an adapter for my slide hammer by welding two bolts head-to-head. One end screws into the slide hammer and the other threads into the pump holes.
