I've been searching on here but wanted to get direct answer.
Pulled apart trans yesterday, input shaft endplay was .068" with transmission sitting vertical on workbench. Outout shaft through hole. After I got inside I found that there was no shim under the torrington bearing for the pump. This would explain all the slop right? The book I have claims that shims are .017" nylon and two can be stacked to tighten up tolerance. Local GM dealer was of no help. Now if I order parts do I just need a shim kit or will I have to use a thrust washer and eliminate torrington bearing?
Also where can I order parts from ebay, Makco trans parts (never heard of this one until today). Any and all help would be appreciated. This is my first tranny rebuild.
