trans swap
Talon,
This swap should be rather easy.The 700 is a direct bolt up in place of the 350.I would use the column from the Sub so you have the correct shift indicator.You will need to hook up the TV cable to the carb and adjust correctly to get the correct shift points.I had an 84 C-10 and it had a 700r4 with a 305 and 3:08 gears.It got 18-19 mpg on the hwy.Good luck
Talon,
