A Learning Hobbist
Problem.....
Problem!! When i was installing my shift kit, I lost the clip that goes from the kick down cable the lever on the valve body. Does anyone know where I could get that part, I live in MA, or what would be good to use to make that. I would imagine a piece of wire, but if there a certain gage that I should use?
Thanks once again.
Steve
1979 Chevy truck
sb350
K10
th350
It is spring steel.
With the amount of movement a softer material would wear out quicker.
I have never tried anything different but a coat hanger would be about the same gauge.
A Learning Hobbist
Discussion Starter #4
I'll try to hit up a junk yard or tranny shop. If I can find one, I was thinking of using a 19gage wire.
Thanks for ur input. Also, I will try the coat hanger.
Steve
