1 - 13 of 13 Posts
Rod...from a Chrysler?
I'm trying to give away parts to local car guys as I don't want to scrap them, and not sure about what I believe is a 375 extension housing and output shaft, or if they even go with each other. The output shaft has a reluctor on it and is 27 spline. I thought all the older stuff would have a speedo gear there.
Automotive tire Bicycle part Rim Gas Automotive exterior
Motor vehicle Table Gas Engineering Desk
Discussion Starter · #2 ·
Oh yeah, I found a 5-1/2" extension housing as well. What the heck would that be from?
And can someone tell if those are 4 x 4 output shafts?
Automotive tire Microphone Rim Engineering Gas
what's going on with that hammer?
What, the Pugsy special?
It's not for tranny work. I know I'm a bit of a hack, but not that much.
It's actually for metal shaping. Plastic one end and planishing hammer die in the other.
Or the blue one? That's for shaping over a hollow, like on a stump, or even the end of a piece of large pipe, hence it's name "hollowing hammer". It gets some stretch into the metal right quick.
  • Like
Reactions: cerial
Yeah, first post pics are Th-375, late-80's or early 90's and maybe even newer as the "3L80" in GM speak
Thanks. I thought they were older and was wondering about the use of a VSS so early.
That 5-1/2" tail stock still has me baffled. Can't find it anywhere on line.
Discussion Starter · #9 ·
Looks like a 4L80E housing.
You may be right. I got my 4L80e ripped apart in boxes. I may have left this out as I have a GV unit bolting up to the back of it.
Better hang onto it.
Flip the short tailhousing over. Is there an oil lube channel hole to the bushing? 4L80 tail is pressure fed to bushing.
The short T-400 output shafts were 4x4 length shaft for early 205 t-case applications, also 2 w-drive short tail
Discussion Starter · #11 ·
Thanks
I've got three of the short output shafts. Did you see many of these break when you were in the business? Hate to toss something a fellow car guy might need one day.
yes, oil passage. It's the one off my rod's tranny as mentioned. I can't remember jack anymore.
Automotive tire Bicycle part Gas Rim Auto part
1 - 13 of 13 Posts
