I'm rebuilding a '75 T-400 and want to install an aftermost 34 element intermediate sprag. I haven't disassembled it completely yet.
I understand the '75 drum has a check ball relief in the drum, and to use the 34 element sprag I need the early style clutch piston and drum which has the relief in the clutch piston. I have an early hub but no piston. Can I drill a relief in the old style hub, matching the relief I expect to find in the '75 hub, and proceed with the 34 element sprag? I can't find the early clutch piston and GM doesn't carry them.
Can someone give me a quick and dirty on how to make this work?
Thanks, Larry
This "check ball" is supposed to prevent centrifugal apply of the high-gear clutch at high rpm, like to bleed off pressure.
Thanks, Larry
