Hello, i have an problem with my TH400, i diassembly it full, and assemble it again with the same parts, i put it in the vehicule, put oil on it and run, the vehicule move good like 30seconds, and then al gears are like it was in neutral, so i popped out the cooler line and start it, and i observe that it spit some air, so i plug the oil line again, run the vehicule, and it do the same thing, 30sec and all gears neutral, it change gear very well, the level seems to be right, should i add more trans oil?, i have a deep pan, and i put like 10quarts of oil on it, there's a method to bleed the air?
pd:sorry for english im from Chile
Regards
Regards
