1 - 6 of 6 Posts
DMMARTIN said:
WE ARE TRYING TO BREED A T-5 TRANSMISSION TO A `48 FORD FLATHEAD.
WE HAVE ORDERED A ADAPTER KIT FROM CORNHUSKERS. WE DON`T HAVE
THE TRANSMISSION YET. ?????
So , what is your question?
:cool:
The Maintenance Geek
If you're asking what T5 to use, With a flathead I'd
probably go with one from a 2.3L Mustang, mainly
because of the ratios, 5th gear will be usable...
K
If you are using a t5 to put in a model A or 32 ford you should take one from a S10 as the shifter is closer to the engine. A t5 from a mustang will be a couple inches behind so you will have some problems shifting. A lot of people use the s10 transmission case with camaro gears because of better ratios.
Violating consensual reality
The GM and Ford T5s have different mounting patterns to the bellhousing. You might be able to mate the Mustang gearbox with the S-10 tailshaft and shifter housing. I know it works between the Camaro and S-10 units.
Strummin
1 - 6 of 6 Posts
