Glad To Be Here
aces said:
with a t bucket do u need a booster for brakes and steering setup
You would not need power steering due to the light weight of the vehicle.
You do not need power brakes either but that would be an option if you want that feature.
put this in perspective. a T bucket weighs in at 1,800-2,200 LBS, I can stop my 2,551 LBS '67 Falcon with non power drums with little effort.
My "T" bucket weighs 1600 lbs. With VW disc brake calipers front (10 in. rotors) and 10 1/2" drums rear. When originally built, I used a fairly large (1-1/16") master cylinder. I did not like the pedal effort and after a few years, went to a 15/16" master. The car now feels like power brakes!
T-Bucket, Corvette, Mustang
My T weighs 1,550. I have the brakes and rear-end out of an S-10, with discs on the front (Wilwood), 1" manual MC, and it has plenty of stopping power. If you have disks on the front and drums on the rear, make sure you put a proportioning valve in the system so you can adjust the front-to-rear brake bias if needed. Good luck to you!!
