I purchased a new T5 input shaft and cluster gear a couple weeks ago. I've got it all back together but I noticed that the input shaft doesn't line up with the gear on the cluster. All the other gears are lining up perfectly except the gear from the input shaft.
When I take out the flat roller bearing between the input shaft and 3rd gear, then it lines up but clearly that's not right also.
See the attached picture. I have the tail housing and input shaft bearing retainer on with the correct pre-load on the input shaft. You can see how the gear on the cluster overhangs the input shaft gear.
Any thoughts?
Thanks!
Any thoughts?
Thanks!
