I have a 99 Tahoe open diff. which is going out. Anyone know what years interchange? Pickups, tahoe's GMC's, etc. Want to do brake to brake.
Thanks,
Bill
Thanks,
Bill
bgreen63366 said:I have a 99 Tahoe open diff. which is going out. Anyone know what years interchange? Pickups, tahoe's GMC's, etc. Want to do brake to brake.
Thanks,
Bill
Its not hard, just a messy job. The owner of the shop I work part time at has a Tahoe and his was the first we did, we have done several since. I could not believe the prices for a bone yard rear end. The whole thing only takes a couple hours or so. Make sure you change the axel seals while you are in there and be sure not to loose the shims for the pinion. The procedure is fairly simple. You need to pull the spider gear shaft out after removing the lock screw, push the axels in and remove the c-clips, a magnet stick is real handy for this. Pull the axels out, be ready some oil may leak out of the axel tubes, dont get it on the brakes. We usually put a clean rag in the hole. Remove the carrier end caps after marking them. Remove the carrier assembly and inspect the bearings and races. Next remove the pinion nut and yoke and outer bearing. The pinion should then slide out of the case from the side where you removed the carrier. The bearing that is on the shaft is usually a press on so you will need someone to press it off and the new one on if you dont have a press. Dont cheap out, change all the bearings while you have it apart. The only tricky thing when putting it back together sometimes is getting the spiders lined back up. Keep lots of rags handy as it is a messy jobbgreen63366 said:Hums like crazy. I have had to replace the diff cover gasket several times, it wears itself loose and leaks gear oil. I ran it low too long once, been humming ever since. Thanks for the help. I think I will try and do this myself. I appreciate the tips.
napa has the kits I believe. I think the ones we had were from the AC Delco line from a local distributor. If you cant find a kit, you should be able to get the numbers off the bearings after you get it apart. GM also may have a kit but it probably will be expensive.bgreen63366 said:Looking on Autozone's website for a rebuild kit. Doesn't look as though they offer one. Would you guys have an idea of what parts I would need?
