cruiser enthuiser said:
Hey Fellas. New to this forum. Hoping some of you guys with TBI experience can help me out.
I recently converted my early SBC 350 to TBI. I've worked through a few issues with rough idle, vacuum leaks, etc. It runs pretty well now. However, when I went to smog test (required in Nevada on my '68) my CO emissions at idle were very high and I failed. Interestingly, I am getting a 44 error code for "lean exhaust"
. Apparently the computer thinks it's running lean and is enriching my fuel mix?? I've changed the o2 sensor with no change. I've also changed coolant temp sensor, checked for a stuck EGR, checked for vacuum leaks. Not sure what else it might be. Anyone got ideas?
Thanks in advance for your help.
Ed
What exactly is the engine configuration, and what or who's TBI are you using?
OEM TBI is designed around a very specific engine configuration, 305 or 350 or 454 (each of the engines has a chip specifiic to it), with a very mild cam of 160-170 degrees duration an LSA of 112-116 degrees and less than .4 inch lift at the valve and compression around 8 to 1. Anything other than this will quickly get into custom chip territory. Same goes for headers instead on manifolds, this changes the back pressure which will affect the mixture by way of the computer and O2 sensor. Also the temp of the O2 sensor and engine coolant are both critical. Sensors come unheated (2 wire) and heated (3 wire); heated is better as it isn't sensitive to where it's placed from the head pipe. Two wire needs to be jammed as close to the manifold as you can get it or it won't stay hot enough to signal the computer to go into closed loop operation. The engine, also, needs to be at least 180 degrees to signal the computer to come out of cold start choke enrichment mode as well.
The system is dependent upon a catalytic converter and in some instances an AIR injection system as well. Most emissions as a percent of total exhaust output are at or just off idle, this is what they check for; not how many absolute tons of the stuff comes out the pipe. So a cat converter and possibly AIR do a lot to clean these emissions. However, AIR on an engine with a computer not originally designed for it will fake the O2 sensor into thinking the mixture is lean and it will try to correct with added fuel. The same thing will happen if there is an exhaust leak between the engine and the O2 sensor.
TBI is also very sensitive to fuel pressure, you need to know what it is, 10-12 pounds is plenty.
What did you do for a distributor? The OEM HEI is computer controlled. HEI is the minimum ignition that will work. Misfires on idle from old fashion ignitions will make the mixture hugely rich. While the computer if it's in closed loop would try to lean it thru the O2 sensor, its authority to correct the mixture is limited to about 10%, if that, so anything beyond that the computer can't fix given one misfiring cylinder makes the mixture at least 12.5% rich at the O2 sensor.
Another thing is idle speed and manifold heat, the TBI intake needs a lot of exhaust heat to vaporize the liquid fuel and the idle speed needs to be over 600 RPM to help mix the fuel and air. If these conditions aren't being met, it's likely one or more cylinders are see a stream of liquid fuel that can't be consumed given the amount of air present.
So you've got a lot of stuff to check out.
