recently purchased a 93 stang with a 347 supercharged.had to replace head gaskets.imagine that with 15 pds boost.used felpros supercharged gaskets & studded block.ready to set ting & vavles.no tdc,atc,btc on balancer.how to determine where tdc is.
Well if you do not already have a dial indicator you are about to go shopping for one.. this is a tool that is needed if you are going to be doing anything serious..
Now set it up on the block so you can measure the height of the piston in #1 cylinder and rotate the assembly unitl you have determined exactly where the piston reaches TDC..then scribe the balancer at that point..Now you know TDC and it all gets easier from there..While you are at it put some timing marks on the balancer as well..
