Hi Guys,need help on a 56 holly teapot problem. The carb was rebuilt .After install it would start and barely idle with fuel running in the secondaries and the plates were closed. Installed a regulator on the pump and problem changed to flooding after wide open throttle With gas running into the secondaries and the plates in closed position. Leave it sit and the gas drains out then the cycle stars over. Let it idle, its OK, then give it throttle and manually open secondaries for a second and the fuel won't start flowing into the secondaries. Fuel pressure sitting at about 3 Lbs. Help John
