I don't see why not. All that's needed is a tube spacer the right length to result in proper pinion bearing pre-load. Just be prepared to do some assembly / dissassembly until you get it right. Just curious, why wouldn't you use a crush sleeve?
Bob
Save a horse, Ride a Cowboy.
Definitely, several differential sources supply solid sleeves and shims to replace crush sleeves.
Crush sleeves are not reuseable.
Solid sleeves are a popular addition for Ford 8 and 9" rear ends. Never build one without a solid sleeve. period. Currie has the Ford kit for about $ 10.
Solid sleeves are a much better way to do it because severe power loading cannot squish the sleeve and cause pinion slop and eventual gear wear or breakage.
