1 - 2 of 2 Posts
Jig Master Kermit said:
anyone know the cooling line pressure on a TH-350?
and aprox. fluid temp.under normal driving conditions?
Pressure in cooler lines can run 25 psi to 80 psi , depends on setup of the trans for performance use or stock...
oil temp can be all over the board depends on factors in you vehicle to the local out side temps , to type of converter you have
1 - 2 of 2 Posts
