Hello fellow hot rodders.
I have one question for you gear heads. what is the maximum heat a std 350 trans can withstand, and where have you reached the "beware" point ?
Best regards and take care.
bentwings
That's good info.
My new Wllys has a trans oil cooler in front of the radiator and no cooling provided by the radiator. So far even with the 3000 stall converter I have not exceeded 185 deg even on the dyno. Normal cruising is about 160 deg. I'm happy with the install.
