I have been doing searchs on the board here for a hour or two reading about the 700r4's and 2004r's.
i have a 1982 pontiac grand prix with a TH350, but once i change the rear gears out i will be in the 2800+ RPM depending on what gears i decide to go with so a O/D would be nice. i just bought a new crossmember and had to pay $250 by the time it got here so if i need to replace it i will forget about the swap and just pick out some differnt rear gears.
The trans will come from a junk yard car or the paper and would run as is. so aprox how much HP and torq can a stock 2004r and 700r4 handle?
what are the mods neeeded to swap?
2004r
-shifter
-shorten driveshaft (unless TH350 has the short tail shaft? but if its differnt i could probaly get the driveshaft off the car i get the trans from because they came in the same type of car i believe)
700r4
-shifter
-shorten driveshaft
Thank you for your time :thumbup:
2004r
-shifter
700r4
-shifter
-shorten driveshaft
