Hello i'm new here, i have a '83 s10 whit a 4.3 v6 and a th 350
now i have vibrations at 3000 rpm but when i downshift and the rpm gets more it dissapears.
I did some searching on this forum but cant find any awners.
I,m from the netherlands so excuse me if my typing is not so good.
greetings from the netherlands.
Member# 3287
Is this a problem that just started?
Not to state the obvious, but a vibration is usually something out of balance or loose.
Can you provide more information? Where do you feel the vibration in the gas pedal, steering column, or other place?
Discussion Starter #3
The problem just started the vibration goes trough the whole car, also when you got it in neutral and make 3000 rpm.
I checked the Tc and the bolds where tight, oil level is OK and looks good could it be that the Tc is going bad?
