hi everyone
i have an issue with a '70's TH350
transmission fluid is coming out in a stream about the size of a pencil lead through the tranny casting where the lower brass cooling line adapter screws in,
it is no leaking from the threads, but it was a little before i cranked it tighter to try and stop it, well now it puts out a steady stream, through the casting of the case at a point that is about at the end of the threads of the brass cooler line fitting inside the case hole
has anyone ever had this happen and what can i do about it ? has anyone ever seen this happen, i know someone out there has and hopefully knows a good trick to fix it at least for a while anyways
thanks for anything
thanks for anything
