Can anyone help me with a vibration. i have checked all the rear end and have found a wobble on the prop-shaft. i suspect tail shaft bearing or bush, if there is one. Any ideas or help would be appriciated
Who about the brngs in universal? If they are worn the the drive shaft will wobbly to beat h***! Also, could the drive shaft be bent or have a flat spot on it like from running over something and bottoming out there??
hi
tanks for your reply i have checked the u/j's and found no movement i have also checked the prop for flat spots but have not found any the only movement i can find is where the slip yoke go's into the gearbox this is why i wondered if there was a bearing or bush that ican change.
thanks again for your reply
