I had to put a new torque converter in because of the new cam. Got i all back together with the new torque converter and i only had first and second gear. I do no have a kick down cable because the transmission will not seal unless the cable seals with an o ring on the bottom side of the tube, but i took the oil and pan off and adjusted it from the inside so that is was all the pulled out and kept it there and got it down and drove it again and now i only have first gear. Any suggestions on things to check?
