I just had my trans rebuilt (TH350) and it is leaking around the kickdown cable area where it goes into the case. Before I had the trans rebuilt it leaked there and I indicated it to the bozo that did the work. Is this an easy fix or am I going to have to pull the tranny out for this one? Or can I just put some black rtv silicone around it and solve the problem? Thanks for any help you can provide.
Th350 leak
You may be able to remove cable from carb to gain enough slack to unhook cable from trans.Saves you the trouble of pulling the pan.
IF your trans detent cable or the filler tube have the rubber sealing sleeve ( NOT the O-ring)
It is best to install the rubber sleeve into the tranny case first , then the cable end or filler tube.
Discussion Starter #5
th leak
I should have included that the kickdown cable is not used since this tranny is full manual and the cable is actually cut off several inches from the case.
