OK, here is my problem. I have a TH350. Last week the transmission functioned perfectly. It is still very new - it only has about 300 miles on it. Yesterday, I was on the highway, and the car was driving great, then it dropped down into second. I put it into neutral, then back into drive, and it went into 3rd gear again. The problem continued. It would stay in third for a while, then drop down into 2nd. So, I brought it home, and I check the fluid level. It was fine. I put in another quart anyway, just to make sure it was not a low fluid problem. That did not fix it. I have not messed with the kick down cable. It is new, and still in good condition. The adjustable modulator is new, still in good condition. I am sure the shifter is adjusted correctly - it goes into 1st gear just fine. When it is in neutral, the car does not move at all, then when I throw it into drive, the car wants to move. It feels like only air is in the converter - but, if that were true, the car would not work in 1st, right? I have a pretty radical cam, but the transmission used to work just fine, and I have enough vacuum to run power brakes pretty well.
I read around on the forum, and other articles suggest that it could be the filter. My question is, how would the filter get clogged up so soon? the transmission is new.
Also, I want to install a B&M shift improver kit - could that fix the problem?
thanks in advance for the help -Ed
