Hi everyone, I've got a problem that might be a simple fix or might not...
I've got an 86 cutlass and recently swapped the old 307 for a sbc and th350. I called ******* perf. and they set me up with a nice 3000 stall converter. When I go from park to reverse or neutral to reverse, it kills the engine dead. When going from neutral to drive, rpms drop a little and I have to give it a little gas but it doesn't stall.
The carb is a holley 4150 770cfm street avenger. I really doubt I have any vacuum leaks and the trans shifts very nicely in all three forward gears. I've been thinking the problem is tuning the carb, I haven't got the idle set properly in drive.... but would this kill it automatically when I shift to reverse? I also advanced the timing a good bit to see if that would help, but apparently not.
I asked around some tranny shops and they said the problem was I have a non lockup converter and it should be a lock up.... but would the trans shift fine going forward if I had the wrong converter?
