1 - 1 of 1 Posts
What after market built up TH350 has a transbrake and reverse valve body? I need to replace my current TH350 (has been rebuilt twice in the last 7 years) it is slipping badly) and the vacuum modulator hose is hooked up fine.
I have a Gear Vendor and custom drive shaft so to save on expenses, I will swap out the TH350. Not looking to upgrade to TH400 or 700R4.
While swapping the tranny, this will also be a perfect opportunity to change the 3,200 stall convertor to a Yank 3,800 - 4,000 rpm stall convertor.
Thanks . I can only afford in the range of $1,500 to $2,000.
I have a Gear Vendor and custom drive shaft so to save on expenses, I will replace with new TH350. Not looking to upgrade to TH400 or 700R4.
While swapping the tranny, this will also be a perfect opportunity to change my current 3,000 stall convertor to a Yank 3,800 - 4,000 rpm stall convertor.
Thanks
1 - 1 of 1 Posts
