1 - 2 of 2 Posts
Banned
ok well some of you may remember that i have a th350c i pulled from an 81 chevy pickup i junked years ago that was powered by a 350 olds diesel.
i saved it over the years in case i ever needed it for anything.
i got rid of the diesel torque converter thinking i could easily locate a cheap gasoline version one
in which i have been proven very wrong
its a perfectly good trans id like to make available for use instead of taking up space here as usual.,
can i simply hack off the o ring center input shaft and use a non-C converter?
just to run the trans?
thanks
when will it rain???
thanks
no,the stator must be changed, and the t.c.c. valve needs to be blocked, and a hole drilled in the small plate next to the tcc body.
as far as a converter goes, whatever it takes trans parts has 1, heres the link:https://www.wittrans.com/QuestionParts.aspx?Question=1641
1 - 2 of 2 Posts
