35201 - 35220 of 35263 Posts
I'm learning a little about CAN bus issues on DD the 2nd's 11 Corolla. Crazy stuff... It's going to the shop on Monday, but I'm trying to learn a little to do a few simple diagnostic tests. I spent a good part of my Friday messing with that. She said that the EPS light, brake light, ABS light, and maybe one other dash warning lights came on once she turned into our driveway on Thursday evening. All of the obvious stuff checked... Brake fluid level good and clean, no obvious leaks anywhere. All fuses good, voltage on both sides, battery voltage good, alternator charging properly. My code reader will not communicate with the ABS module, so I took it to my buddies shop. His real scan tool would not see it either. He didn't have time to dig into it, but said it looked like a CAN bus issue. Good thing she still has the Impy to drive to work, for now, anyway. I'm going to spend a few minutes more on it this morning, and then I should be heading over to dad's shop to work on the Chevelle finally. Yesterday was spent on yard work and replacing outer door handles on the hooptie Sienna van. Then my bride and I took the 57 out for a run to the DQ.
Sent from my moto g power (2021) using Tapatalk
I needed a cheap commuter I was either getting a 90's geo metro or a first gen s10. Both of these are stupid simple to work on and are good on gas.
I found a clean 91 metro 5 speed convertable for $1800 then it disappeared for a week and when it returned was $2000 more. So nope. I can pull and rebuild that 3 cylinder on a Tuesday night. But I am cheap and 4k is a lot of gas for something that will have a southern unibody shot after 10 years in Michigan.
So I went on the hunt for a s10. Now I have had 13 so far and I picked up number 14 today. I have been looking for this exact truck for a while.
91 with a 2.5, 5 speed, 4.11 rear(base no options)
Wheel Automotive parking light Tire Window Vehicle
Wheel Tire Car Vehicle Land vehicle
The exterior is meh going to change colors soon. Frame and such is solid. I believe the mileage just from the frame and underbody condition.
Vehicle Car Motor vehicle Car seat cover Steering wheel
The interior is good enough for me to drive it. Heater works, radio works, windows go up and down, even the doors close without dropping. Notice no cracks in the dash.
Automotive tire Electronic instrument Audio equipment Motor vehicle Font
2.5 in all its glory.
Car Vehicle Wheel Automotive tire Motor vehicle
No power steering and newer shiny exhaust. Some cracked vacume lines and think I have a few bad sensors.
Motor vehicle Automotive tire Tread Tire Automotive fuel system
T5 will need a clutch soon and I will pop in some new seals when I have the trans out. Shifts great though.
So the person was driving this . Always a good sign when they meet you in a parking lot driving up. But it sounded like it was just a "around town" truck. I took it down the city street and back. For what I paid I was impressed and sold.
I got it back to the house and after taking it around the driveway down the road I went.
Engine has some good pep in it. Transmission shifted great both up and down. I brought the thing up to 75mph. No issues with vibration or sounds or pulling. Even the brakes worked good. Popped the hood and checked the hot engine. Coolant system was holding pressure and oil looked good.
I am going to keep this girl for many years. I need to drop a grand or two into it before she is something I would drive out of state. But I have a very good starting point.
No I am not dropping a v8 into it. I love the 2.5 and am building a lighter 94 s10 with a v8.
This is just a back and forth to work truck. At some point in several years it has great potential to be a electric conversion. But the 2.5 will do just fine for now.
Grand Prix user
Yessir... That is exactly what I meant. I think it was Matt that I took the electric glue gun term from. I like it. Welding will start hopefully in a day or two. I was beat after crawling around on the floor for several hours.
You betcha. Hot glue gun for steel. TIG users get a bigger kick out the term than I do but yeah. Good to see Chevelle action mixing in with the usual flow of fixes. Heres hoping all of it goes your way. :)
'Cause you're the tax man. That attacks stuff when he tackles it.
OK, that was tacky. Where's Weldon Dunn?
Heh. I am excited for you but will contain myself. :)
All clear at IDJ, nothing to report. Ah.
Got up early this morning and spent the day moving my wheelhorse and other stuff out of the garage to make way for the s10.
Tire Wheel Automotive parking light Vehicle Window
Once that was in a 3 hour inspection of the truck took place resulting in a good/bad list.
Good:
NO codes
Fuel lines from tank to filter
Fuel filter
Fuel lines after filter(wipe down)
PCV New
PCV Tube New not cracked(wipe down)
Spark plugs new
Spark plug wires new
Heat vent tube
Radiatior and cooling system good
Radiatior lines(all) Good
Injectior pulse/pressure regulatior(new) Good
Exhaust leaks None
Wiper/washer Good
Heater Goood
O2 sensor Good
Clutch master/slave Good no leaks
ABS good
Brake lines good
Brakes good
Bad
PS tail no running
DS tail no anything
DS mirrior replace
Clutch replace(kit)
Pilot bearing if not in kit
Flywheel replace
Rear main replace
Oil pan gasket replace(pan wipe)
Valve cover gasket replace
Trans output seal replace
Trans front bearing/bearing seal replace
U joints replace
New exhaust doughnut(remove for clutch)
Battery group 75 500cca 2015 replace
Vacume lines 1/8"id x8 feet replace all plastic
Pull and wipe down intake
Intake gasket to block
TBI gasket to intake
Oil filter/oil change
Cap/rotor
Module
Coil(keep old)
Motor mounts replace
Trans mount replace
Sensors
MAP old replace(keep old)
EGR sensor BAD replace
IAC old replace(keep old)
TPS old replace(keep old)
EGR valve old replace
Temporary Paint one color before driving
Windshield replace last before driving
Replace later.
Poly Gas tank and new fuel pump
Battery cables/grounds
Brake lines on rear axle and flexible brake lines
Cab floor repair
Rust free body parts
I will spend the rest of the night sourcing parts looking at reviews and parts prices.
1964 Thunderbird, 390 FE
I started building an exhaust for the golf cart today. Got the flange mostly done, just need to grind down one corner to clear the fin. The original manifold and muffler looked pretty restrictive, so hopefully I pick up a horse or two on the top end. :) The plan is to just have a turn down pointed down and towards the back. I have bypassed the governor and it already spits some flames out the exhaust when I let off the gas, so hopefully the flames get bigger. :D Don't worry, I don't live in the west, (sadly) so fire concern is very minimal. Now I just need a LSD to take care of the one wheel wonder... But then I'll need more power, and then I'll need a stronger trans, then I'll want a little higher gearing... It's an endless cycle.
Automotive tire Motor vehicle Wood Sculpture Automotive wheel system
Rod...from a Chrysler?
Does LSD make you not care about the one slip wonder? I know I didn't care about much last time I used it.
  • Haha
Reactions: Blue64Tbird
today i went to PT, looked at a house, gave them an extremely high bid, finished up a tiny houses wiring, fixed a f'd up 3-way switching disaster in a kitchen, went to the Ho, changed a dual function breaker in a house i worked at in 2016!! came home, played with the dog, yelled at the wife when i went online and got S for answers, logged on. and gee, it's still daylight out there.
up above, i'd say leave the golf cart alone and you dont have to change anything!
Grand Prix user
Aw, thems Pugsy TIGs. A nail file should do. ;)
IDJ report: The Model A job is shot, all but the outside. Envy Green with tan accents. F1 tail end revision parts are pretty much made but not attached. The Cat had or has a fuel pressure hiccup but is a little more done each time I walk past.
I was out there this morning in my PJ's. I figured if I'm gonna get covered in dust, I might as well do it before getting cleaned up. Man, a lot of grinding.
Piddled a little on the Chevelle this morning. Finished trimming the back patch, and then pulled all of them off to get some Ospho in there. That's drying now, then clean that up before primer. Welding later. Then my oldest got here with her Solara. She's still having intermittent speed sensor issues. I went throught the FSM and checked everything I could without pulling the entire dash out. Confirmed that the signal is getting from the sensor to the ECM, and the sensor itself checks out fine. But then it's intermittent. I was able to fix one problem for sure. Ever since we bought the car the fan blower motor would vibrate pretty bad on the higher speeds. Sice I had the covers off to get to the ECM today, I pulled the blower motor off to clean out the squirrel cage fan. Found the problem... Poor little guy went on the carnival ride of his life. Literally. Fan turns nice and smooth now.
Automotive tire Hood Grille Automotive lighting Motor vehicle
Automotive tire Cuisine Gas Automotive wheel system Wood
