The great thing about drums is if you match the Inside diameter and width you can often bolt replacment on even if you need to drill, elongate holes, or machine a bore.
I would start with the hub bore then the diameter then width knowing holes can be drilled easily enough as most drums align via the hub.
After a few hours searching you may find a modern drum that can fit with minior machine work.
On the springs/cables you may find modern replacments. But generally unless its broke it will often just need a good cleaning.
