No pics today. Today was day two on Leia (1961 Vanden Plas "4 Litre Princess" limousine with Rolls Royce bodywork) front suspension, steering and wheel bearings. Got the right side "Armstrong lever hydraulic damper" off the car and off the kingpin carrier. Some numb nuts booger welded the top fulcrum pin to the arm on the damper. I'm going to have to grind off the welds and knock that pin out before sending it off to Peter up at World Wide Parts in Madison WI for a rebuild to "better than new." Now I'm working on the right side today. It's also going to have issues with the upper fulcrum pin once I get it loose. The pin on this side is about 2 inches too long, and booger welded to the arm as well.
I've also been slowly working the remaining thermostat housing bolt back and forth on the GM 4.3L Vortec V6 in this one. It turns about a quarter turn now before hitting a "stop". Been soaking it in Blaster for an hour or so while working on the suspension, then going back and wiggling it some, spraying it with the Blaster again and going back to the suspension. I do not want to break that stud off in the intake on this one. BTDT, and it's no fun to fix. Not horrible, but not something I want to repeat.
I'm still not 100% sure how I'm going to release the tension on the coil springs safely to get the lower wishbones out. There's a Vanden Plas special tool, 18G76 Front Suspension Spring Compressor. Might be in the Austin special tools as well, but I don't have one of those, and I don't think I can source one. Today I got some longer bolts for the lower spring seat plate. Tomorrow, I'm going to try to lower the lower spring seat a little at a time with the longer bolts until the tension is released (hopefully all the way released). I'm hoping that will do the job.
