I have never used any of the panel adhesives available today so I have a few ideas and notions that may be incorrect.
Currently on my mind is using panel adhesive in place of welding in patch panels.
I realize there will be a height difference and an edge to deal with, I am curious about durability over time of the bond in an overlap joint such as this versus being used in a pinch weld area as I have seen it used.
as always, Thanks guys!
No durability problems and the only drawbacks is if not done properly you could see a ghost line where your seam is when there's temperature changes and also there is limited adjustability (hammer&dolly work) that you can do after the cure. Spend the time to fit it properly before bonding the parts! Often times when the car sets in the sun a faint line will appear then dissappear when it cools. There are ways to avoid this though and you should fit the panels so there's some room for a fiberglass reinforced filler over the seam. Also grind the patch panel edge to a knife edge taper and have 1" of overlap for the bondline. Go to Fusor's website for some good technical info. And with a lifetime guarantee it makes sense to use it in many situations.
Hotrodders.com moderator
What Bob said!!!..good stuff that adhesive..And saves some of us time and frustration trying to weld thin metal..
Sam
