So I ordered a 9” inch housing axle kit and a 3rd member with the Truetrac from Quick Performance. I went out to the shop this morning going to start putting the rear-end together.
Well, when I started trying to press the third member bolts into the housing, they don’t want to press in. I put a couple of washers on the bolt and tried tightening it down but the nut gets almost too tight to turn before the head of the bolt reaches the housing. Then on one of the bolts when I was trying to take the nut off, I actually broke the bolt. I believe the problem is there is a build up of powder coating inside the holes. I’m considering running a drill through each hole to clean off the powder coating to see if that helps. Does anyone have any ideas or suggestions? Also, does anyone know the exact size drill bit I would need so as to not open the holes up too much?
