Hey guys, thanks to everyone that helped with the 350 thread last week, but iv been looking at parts, prices, and my money..... And decided I can't build a plain ole 350 with a perfectly good 4 bolt block. So 383 it is. I finally got everything put together and I need yalls input on how you think this will run and if it'll run on 93 pump gas (non-ethanol).Here goes.
.030 over 4 bolt block ( .025 deck )
Eagle specialties 383 external balance rotating assembly w/ +12cc dish hyper pistons. 5.7 rods, 3.75 stroke
Lunati voodoo cam ( PN 10120703). 268/276 advertised. 227/233 @.050. 489/504 lift. LSA 110. ICL 106.
Fel-pro gasket .041 thickness/4.166 bore.
64cc double hump heads. 2.02/1.60 valves, port, bowl blend, completely reworked and ready.
Holley 670 street avenger vac secondary
Performer RPM air gap intake.
If I'm figuring right I got A static comp of 9.675 and dynamic at 8.976. How would this run on 93 pump gas?? I could 0 the deck but it'll up my compression to 10.2/9.5. Hows that on pump gas?? I know what everyone is saying about the heads..... They will eventually be changed out with AFR's after funds are rebuild. But that might be a little while so I need it to run with the old iron heads good.tell me what y'all think about this and double check my comp numbers just to be sure. And if someone has a desktop dyno or know what this motor would be capable of producing, I'd like to hear it. Thanks everyone.
