Hello,
I just wanted to see what the popular consensus is for using a single plane intake vs dual plane intake for a multiport EFI conversion. The engine is a 390 FE engine. I confess I am a little confused by what I read and what has been used in production on some stock EFI cars. If you'll indulge me; the popular opinion is that the dual plane intake for carb or EFI is better for regular street use. OK I can see the benefit for a daily driver. But this seems to be at variance to what GM used for their second gen small block, the LT1/4. We have a 1996 Impala SS and the intake has ~3 inch runners into a large open chamber and that's it. I would say it's as single plane as single plane gets. The car doesn't appear to suffer at the low RPM's. Now of course these cars are ~4300 lbs, come with a 3.08 rear axle gear and has the steep 1st and 2nd gear of the 4L60E transmission. So you can see it's hard to dismiss the use of a single plane intake with multiport for daily driver use if it seemingly works well in this application.
The other reason I went with a single plane intake with EFI ports is there is no dual plane intake offered for the FE with multiport injector ports. Sure it's possible to modify a dual plane intake, but not without a lot of work and skill.
The application this is going into is a 1966 galaxie 500 XL. It should be around 3800-3900 pounds, retains the factory gearing of 3.0 and its C6 transmission. It will be nicely optioned (PS, Power Ford 4 wheel disc brakes, PW, PL, factory AM-FM radio, etc) along with factory air con. Although an overdrive transmission will be in its near future when restoration/modification is completed.
The engine specifications are:
1.) ~396 cid (30 over 390)
2.) Edelbrock RPM aluminum heads (larger valves, medium riser ports)
3.) Rollerized valve train - Advertised Duration 286/290 Crane 349551
4.) Custom made Diamond Pistons 10.5: SCR
5.) FPA headers with 2.5" exhaust and cross over
6.) Multiport EFI with 43 lb injectors. Calculated gross horsepower @ sea level is just north of 500hp at 5600 RPM although that was with a dual plane and a carburetor.
Here's a few pictures of the intake and engine so far.
Pay no mind to the jar of shavings, this intake took a large amount of porting to gasket match.
Pardon the shop, it's a mess
This is where I am currently with it.
Thank you for your thoughts and time.
Cheers
Cheers
