Will heavy pulleys on a 283 cause the rear of the thrust bearing to get chewed up? I understand a tranny can exert forward pressure on the crankshaft if there's too much end play.I'm asking because I had all the pulleys and belts from an 87 Chevy bolted up to the 283 and and toasted the crank on the rear of the thrust bearing.I noticed the pulleys were quite heavy when I took them off to change my cam.
