Just finished tuning in my 350 re build, noticed a slight ticking, coming from the valve train. Drained the break in oil and replaced with the Joe Gibbs break in oil... ticking got worse.
Re checked valve lash, seems to be fine... as rpms increase to around 2000 it's clicking very loud, oil pressure is at 45-50.
it's a 350 sbc, .60 over
Stock bottom end
4 relief flat tops
Lunati Voo Doo 268/274 cam & lifters
186 double hump heads, with 2.02/1.60's, screw in studs and guide plates
600 cfm holley, 1 3/4 headers
Timimg is 22* int. 14*mech, 36* @ 3000 all in
350 tb, 3.73 rear gears
2000 stall
Truck runs like a scalded ape!!!
this ticking just wont go away! changed the oil again to a thicker oil, re checked lash again for the third time,:sweat: still clicking. Got messy and pulled the valve covers, and all are pumping oil just fine, none are bottoming out, and the geo seems good on the stems.
The only thing that is not new on the motor was the aluminum roller tip rockers. Not marked, but im sure they are the proform (blue) roller tips. I have new Comp Steel roller tips on the way.
Is there anything that i may be missing? So far this has been a great re build, love love love the way this things runs! just the ticking is hard to find, and driving me crazy!:spank:
Would the guide plates cause a tick or a rubbing sound? this is a TICK
Stock bottom end
4 relief flat tops
2000 stall
