1 - 2 of 2 Posts
I have recently installed a ford power assist steering control valve and slave cylinder in my 38 Dodge. The tie rod end that goes into the steering arm is a little to big and I can only get the castle nut on about half way. My question is... Is this a 7.12 degree taper? I need to purchase a ream to enlarge the hole. I would feel a lot better about purchasing a tapered ream if I was sure of the taper.
Race it, Don't rice it!
That's easy enough to figure out. Get some clay and fill up the socket. carefully pull it out and measure the angles with a protractor.
OR
Chevy Monte Carlo and the likes cars have tie rods sockets of 1.5 or 7' so you can take it a parts store and see if it will fit.
You can also measure the big hole, small hole, lenght and some trig will tell you the taper.
1 - 2 of 2 Posts
