1 - 7 of 7 Posts
I appreciate all the help everyone has offered on my tilt front end-got an electric actuator (ball screw) 6" travel and its almost installed. I now need a switch that can reverse the polarity so I can make it go up AND down-the actuator has 2 wires and you just reverse the polarity to switch directions-any suggestions or websites for a dash mounted switch?
Thanks again
~TIM~
RELAYSSSSSSSS
I CAN'T STRESS ENOUGH THE USE OF RELAYS. LESS CHANCE OF A FIRE FROM RUNNING WAY TO MUCH AMPS. THROUGH A SMALL WIRE. IF ON MANY APPLIANCES IN YOUR AUTO YOU DO NOT USE RELAYS YOUR SWITCH LIFE MAY BE SHORTENED BY AS MUCH AS 90%
GOOD LUCK
You are looking for a double pole, double throw, center off momentary switch Any decent electronics supply house will have several different styles. The actuator wires will go to the center two terminals. Plus and minus will go to both ends but reversed on one end.
1 - 7 of 7 Posts
