1 - 6 of 6 Posts
I am replacing the timing cover gasket and seal.
What is the best brand seal and part number I can buy.
This is the last one I want to buy.
I have a new balencer and am looking for a seal .
WFO
I've had no problems from Felpro and NAPA seals. NAPA used to be the only place locally I could buy a single seal. Since then, Mr. Gasket and others have started selling seals on the performance parts asiles of the major parts stores. I have used a couple Mr. G. seals and have had no reported problems but the engines were gone from my sight shortly after being built so long term I cannot say. Be sure you lube the seal lips.
The thing that HAS been a problem is aftermarket timing covers having poorly located crank holes.
The seal that I am replacing is a National rubber seal and I have a new sleeve on the balencer.
The cover is a factory steel cover on the ZZ 4 engine I did pick up a small gasket kit for a cam change and the seal in the kit did not have any numbers on it so I am just checking for the best one to replace.
The new seal "feels" softer than the old seal which has 40K and is 10 yrs old, I just did not like it as there was no numbers on it (cheap)!!
Thanks for the info
I have always used Fel-Pro or National seals from NAPA. Most problem leaks from the timing chain cover seal are due to a worn Harmonic balancer. It is hard to believe the seal wears a groove on the balancer.
I picked up a Timkin seal #9845 he said it was a Viton seal and should be good for 100K !!
1 - 6 of 6 Posts
