WFO
If the firing order is 18436572, you can use 6. Other FO's vary, but use the same principal. But you only need to reach the plug wire anywhere along its length, unless you don't have an inductive pick-up light.
ratrod47,
The firing order is different but you still use the number 6 plug, because it is opposite the number 1 cylinder in the firing sequence. Do you want me to post the firing order?
Good Luck
Scholman
