1 - 2 of 2 Posts
When putting new timing chain on SBC, where should the timing marks be when the engine is TDC? Instead of going by what I did years ago on my camaro, I followed the directions given by CompCams...now my truck won't start and they won't discuss it over the phone.
Install the timing set with the crank gear at noon, cam gear at 6:00 O'Clock. This will put # 6 at firing. Rotate the crank one full turn so that #1 is on firing and install the distributor with the rotor pointing at 5:30 O'Clock. Run the wires. Done.
1 - 2 of 2 Posts
