Looking for some help here. I have a sbc in my 1940 Olds Coupe, just rebuilt and has been running great. Recently put in a brand new Pertronix flame thrower dizzy and coil, set the initial timing at 16 degrees, all in at 3,500 rpm is 36 degrees. Engine ran awesome all the way through the rpm range. Recently I notice it was idling a bit rougher than normal, checked a few things, then checked timing again just to make sure it didn't move slightly. It reads about 18 degrees after TDC at idle, just about off my timing tape with vac can disconnected. I changed timing lights, plug wires and checked everything I can think of. If I turn the dizzy to try and get it close to 16 BTDC, the engine sounds like it's going to come apart, can't get close to 16. How the heck is the engine running great but the light says I'm know where near where I should be?
