If hitting the pedal drops the idle speed back to normal, the choke is open. Is this happening after the engine is warmed up? If so, check for binding in the linkage or at the carb. I once had a wire harness bundle move into a position where it would occasionally cause the throttle to hang up. I've also had a throttle body-to-main body gasket that stuck out into the throttle bore just enough to hang up the throttle blades. And if you have a cable throttle, the braided cable starts to wear with age and bind in the sheath. There are a lot of possible causes unrelated to the choke.
