It's the stock 1965 383 Chrysler motor in my Plymouth Fury
2 barrel carb
All kinds of questions
I took the heads in and had em gone through, cleaned, checked, hardened seats (it was still on leaded fuel even)
The same old rockers are on it
Now for some questions... If the lifters are hard to pull out of thier bore should they be changed? They're hyrdraulic lifters btw...
I'd rather not change them because I'm keeping the same cam... I don't know how much I should worry about putting new lifters on that old cam...
Also, I mixed up all of my rods on accident, is this a big deal? I know it don't cost much for rods but I have ALOT of little things I have to buy for this car and I am strapped for cash.. TIME IS A MAJOR FACTOR, I need to be driving this car SOON (as in a couple days soon) so I cannot afford to save up for extra parts.
If I get new rods, do I need new lifters and vice versa...?
Also... I can't find an intake manifold gasket ANYWHERE without having to order it and wait (as i said i need this car going NOW)... My father in law is telling me to use blue rtv silicone on both sides of the valley pan instead...
That sounds like the dumbest thing I have ever heard in my life but I thought I'd throw it out there anyway cause if you guys tell me to go ahead and do it carefully I will for a temporary fix.
Also, do my rocker shafts need to be torqued to my heads? I found my torque specs for my heads, but I can't find them for the rockers.
If so then I'll go buy the book (although I doubt it'll be easy to find)
And lastly, any suggestions on some things I should do?
Common problems during a top end rebuild... Things to watch out for... Good ideas to help out... anything?
There's more... I'll come back and add to this thread later.
2 barrel carb
