I have a 4spd top-loader behind a mellow 289. The car leads a very casual life now as a driver/cruiser--it doesn't have enough juice left to race anyone, but runs smooth. The miles on the trans are a mystery--potentially more than 180,000.
I checked the fluid and it was very low, so I pumped out the old fluid and replaced it w/ the same fluid I used in the rear-end--85w145 hypoid limited slip gear oil that was recommended by the local rod parts guys. The old-timers in there usually know their stuff, but after changing the old trans fluid w/ this new stuff, the tranny is incredibly stiff, and refuses to go into first w/o a throttle blip and a bit of force, then it thuds into gear. Prior to the fluid change, the tranny would fall into gear w/o any effort. Other than fluid, there hasn't been any change. The weather has been rather cold--near freezing at night.
Will this fluid get better w/ some wear, or is it completely incorrect?
