when I put my turbo 350 into drive it makes a noise like small rocks turning in a cement mixer. The noise goes away when I take it to neutral. Is this a problem with my torque coverter? If so do you know what I shoud to to fix it? How is the torque converter constructed. Are there parts inside that could break and make this noise? If not what esle could it be?
Premium Member
Your converter is still spinning/operating when the car is in neutral. If it was the converter Id imagine it would make the noise whenever you are out of park. Does the noise increase as your RPM's do? Sure the engine isn't just pinging?
i just had the same problem and my torque convertor bolts had come out
