Start by checking your gear ratio. Lots of YouTube for that.
What are you engine specs?
If it's real lumpy with power coming on at higher RPM's, a higher stall can help get that breadbox moving.
BTW, it will cost about the same to do the rear end work, as the cost of a GOOD convertor, so I would start there. Only after checking your gear ratio that is. (easy to do, only need to jack it up)
